Quereis dedicar una canción a algún Fiti ??
para lola...
La polla
MUY PUNK
La cosa tiene su gracia.
Ya tenemos ídolos
fabricamos nuestros dioses,
preparamos las poses
siempre atentos a la foto.
Punky de postal, punk de escaparate.
Moda punk en Galerías ¡Muy punk!
A mí no me corteis
aquí vale todo
No me monteis la batallita
de ver quién es más punky
me van los imperdibles
y los pelos de colores
eso no es que me convierta
en un gilipollas de ideas cuadradas.
Ven con tu uniforme
y con tu mente deforme.
Esoy más que aburrido
de ver camaleones
siempre cambiando de piel
con la moda
¡Mucho idiota!
Si no tienes cerebro,
a mí no me molestes.
Identificarte con alguien,
no te va a salvar
Vete de aquí
que piso mierda.
La polla
MUY PUNK
Ya tenemos ídolos
A mí no me corteis
aquí vale todo
Ven con tu uniforme
de ver camaleones
con la moda
¡Mucho idiota!
no te va a salvar
Vete de aquí
que piso mierda.
Me las autodedico..
Linkin Park - In The End
It starts with
One thing, I don't know why
It doesn't even matter how hard you try
Keep that in mind
I designed this rhyme to explain in due time
All I know is that
Time is a valuable thing
Watch it fly by as the pendulum swings
Watch it count down to the end of the day
The clock ticks life away
It's so unreal
Didn't look out below
Watch the time go right out the window
Trying to hold on, but didn't even know
I wasted it all
just to watch you go
I kept everything inside
And even though I tried
It all fell apart
What it meant to me will eventually be a
memory of a time when
I tried so hard and got so far
But in the end, it doesn't even matter
I had to fall to lose it all
But in the end it doesn't even matter
Keep that in mind i designed this rhyme to remind myself how
I tried so hard
In spite of the way you were mocking me
Acting like I was part of your property
Remembering all the times you fought with me
I'm surprised it got so [far]
Things aren't the way they were before
You wouldn't even recognize me anymore
Not that you knew me back then
But it all comes back to me in the end
It all fell apart
I put my trust in you
Pushed as far as I can go
And for all this
There's only one thing you should know
I've put my trust in you
For all this
Y una de Sinkope.. aisss ke bonita es!!
En tarros de miel
Me siento en el umbral de tus ojos y pierdo el miedo
vuelo esta noche tengo antojo de anidar en tu pelo
me riego pero me marchito si no te güelo
y me balanceo despacito empujao desde adentro
Y aunque a veces vuele bajo, cojo altura si te veo
eres rama eres refugio eres agua en mi desierto
y aquí ando de nuevo, en la penumbra perdió
esperando a que vengas y con tu luz pueda ver el camino
me echo a sonreír al verte venir con la luna en tu ombligo
y en el aire cultivo palabras que voy a susurrarte al oído
me siento tan bien que pienso guardar en tarros de miel todo lo vivido
pa cuando no estés, poder untar, con algo dulce el agrio vacío
que empieza a cocer y esto ya no es igual, ya no es lo mismo, ni parecío
que va, que va.
otra noche con la misma flor
y cada noche un aroma y cada noche un color
otra noche, envuelto en sus hojas
su alegría me moja y yo soy esponja que lo absorbe to
su alegría me moja y en sus labios se aloja un dulce veneno
y empiezo a subir de nuevo p’arriba buscando la vida
me siento tan bien, que voy a construir en el cielo un jardín, sujeto
con pinzas
donde ir a plantar flores pa reír, cambiar mis temores
por suaves caricias, y en una calá llegar hasta ti
mezclarme en tu piel sin dejar pistas.
otra noche envuelto en sus hojas
su alegría me moja y me da pa que escoja puestas de sol
y sobre un canchal me siento a flipar
y a recordarte dando paseos
me dejo llevar hacia tu voz
cierro los ojos pa ver tu careto
y vuelvo a quemar hierba pa reír
cambiar mis temores por suaves caricias
sin dejar pistas
sin dejar pistas
It starts with
Keep that in mind
All I know is that
It's so unreal
I wasted it all
It all fell apart
I tried so hard
It all fell apart
And for all this
For all this
En tarros de miel
que va, que va.
con pinzas
sin dejar pistas
sin dejar pistas
la compartes???Eärendil wrote:Me las autodedico..
It starts with
Keep that in mind
All I know is that
It's so unreal
I wasted it all
It all fell apart
I tried so hard
It all fell apart
And for all this
For all this
Por supuesto!!!! contigo siempre!Modro wrote:la compartes???Eärendil wrote:Me las autodedico..
It starts with
Keep that in mind
All I know is that
It's so unreal
I wasted it all
It all fell apart
I tried so hard
It all fell apart
And for all this
For all this
No lo verá nunca xo weno tb una parte xa mi..
Belén Arjona -> Si No Estás
Si te vas, no me dejes nunca más
Te veo volar entre murmullos
Tus manos de agua, por tu cuerpo fluyen ya
Y la noche llegará con sus augurios
Nunca pensé que pudiera perderte
Ángel ahora soledad
Nunca pensé, que pudieras dejarme
Y te escapas, te arrastras
No te puedo alcanzar
Y no estás, y el otoño llegará, la lluvia escampará
Y sin ti, es como dejar de sentir
Si no estás, me siento tan sola
¿Por qué te has marchado así?
¿Por qué me has dejado aquí?
Si no estás, mi alma se encoge
Al pensar que muriendo sin ti
Tengo que empezar a vivir
Si no estás...
Se fue sin más, la vida cruje en su elixir
Se empapa el dolor, de tus cenizas
No volverán, aquellos días atrás
Donde tu alma y mi ser estaban unidas
Nunca pensé que pudieras marcharte
Vuelve, ángel guardián
Nunca pensé, no escucharte ni hablarte
Y me rompo y me caigo, y no puedo avanzar
Y no estás, y los años pasarán, las nieves volverán...
Y sin ti, es como dejar de vivir
Ángel ahora soledad
Si no estás...
Gracias, gracias, yo también me quieroMo wrote:Roci, irremediablemente tengo que dedicarte esta canción: porque " ella se ama mucho" y porque " yo soy mejor que tú" xDDDDDDDDDD.
A La LuZ DeL LoReNZo - LoS DeLiNQüeNTeS
Gilipolleces aparte, muchas gracias, Mokito. Gracias por esa cancioncilla que ya sabes que me parece superchupipiruli y superbuenrollera
Así que para que veas lo agradecida que estoy (por lo mismo, porque ella se ama sola y porque soy mejor que tú), pues te dejo ésta que es un poco pero con la que también me entra bastante buen rollo:
Diego Torres--> Color de Esperanza
Sé qué hay en tus ojos con solo mirar
que estás cansado de andar y de andar
y caminar, girando siempre en un lugar
Sé que las ventanas se pueden abrir
cambiar el aire depende de ti.
Te ayudará, vale la pena una vez más
Saber que se puede, querer que se pueda
Quitarse los miedos, sacarlos afuera
pintarse la cara color esperanza
tentar al futuro con el corazón
Es mejor perderse que nunca embarcar
mejor tentarse a dejar de intentar
aunque ya ves que no es tan fácil empezar
Sé que lo imposible se puede lograr
que la tristeza algún día se irá
y así será, la vida cambia y cambiará
Sentirás que el alma vuela
por cantar una vez más
Saber que se puede querer que se pueda
quitarse los miedos, sacarlos afuera
Vale más poder brillar
que solo buscar ver el sol
Pintarse la cara color esperanza
Saber que se puede...
Querer que se pueda...
Saber que se puede (saber que se puede)
Querer que se pueda (querer que se pueda)
Tentar al futuro con el corazón.
También te dejo este iconillo, que no es justo el que necesitaba, pero no encontré iconillos tocadores de pechos izquierdos, así que éste es el que más se acercaba:
Y ya nada más, sólo recordarte que te espero para cuando quieras comenzar la Reflejo's Paliza Revenge
Así me siento hoy, verso por verso:
Donde habita el olvido (Joaquín Sabina)
Cuando se despertó,
no recordaba nada de la noche anterior,
demasiadas cervezas,
dijo al ver mi cabeza
al lado de la suya en la almohada
y la besé otra vez,
pero ya no era ayer sino mañana
y un insolente sol,
como un ladrón entró por la ventana.
El día que llegó,
tenía ojeras malvas y barro en el tacón.
Desnudos pero extraños,
nos vio roto el engaño de la noche,
la cruda luz del alba.
Era la hora de huir
y se fue sin decir, llámame un día.
Desde el balcón la vi,
perderse en el trajín de la Gran Vía.
Y la vida siguió,
como siguen las cosas
que no tienen mucho sentido.
Una vez me contó,
un amigo común que la vio,
donde habita el olvido.
La pupila archivó,
un semaforo rojo, una mochila, un peugeot
y aquellos ojos miopes
y la sangre al galope por mis venas
y una nube de arena
dentro del corazón
y esta racha de amor, sin apetito.
Los besos que perdí
por no saber decir "te necesito".
Y la vida siguió,
Una vez me contó,
Cuando se despertó,
y la besé otra vez,
y un insolente sol,
El día que llegó,
Era la hora de huir
Y la vida siguió,
Una vez me contó,
La pupila archivó,
y una nube de arena
dentro del corazón
Los besos que perdí
Y la vida siguió,
Una vez me contó,
Me la autodedico ,donde estas princesa? ..
Te recuerdo
Hoy no paro de pensarlo
y no sé ahora muy bien que hago aquí.
Te has marchado y has dejado
otro hueco dentro de mí.
Te recuerdo porque fuiste y has sido
la chispa que me ha hecho vivir.
A tu lado me sentía protegido
y dentro de ti,
ahora ya no existe risa,
ya no hay nada que me haga reír,
y me acuerdo del cariño y todos los besos
que a veces no di.
Desde entonces no veo
otra cosa en mi ser,
y ahora ya te has marchado,
no te volveré a ver,
ya no estaremos solos,
ya no veo tus ojos.
Ando solo y voy pensando
en las cosas que había por hacer,
en los gestos que eran nuestros
que ahora sólo no puedo tener,
los besos que a veces no di.
ya no veo tus ojos.
Te recuerdo
y dentro de ti,
que a veces no di.
ya no veo tus ojos.
ya no veo tus ojos.
perdona que no esté en mi sitio, pero es que estoy totalmente perdido, me gana en todo lo que hemos vivido ...
Otra vez golpean en mi pecho tus labios, una y otra vez golpean y no sé como he de evitarlo ... otra vez te encuentro en todo lo que hago ...
Ostras, Charlie.B, es una de las pocas canciones de "El canto del loco" que me gustan (por no decir la única) Me siento muy identificada con ella, sobretodo con estas dos estrofas:
PD. Pues na, sólo era eso Ánimo :*Charlie.B wrote: A tu lado me sentía protegido
y dentro de ti,
que a veces no di.
Asias AIDA_cantasaetas.Mucho ánimo para ti tambien
Para mi y xa kien la kera tb.. la dedike hace tiempo xo es ke es preciusss!!
ROMPEOLAS (Quique González)
Llévame a ver salir el sol
desde todos los portales de la luna
Llévame al puerto y al malecón
cuando el cielo se nos llene de gaviotas
Alumbrando las calles oscuras
todas las estrellas que hoy durmieron solas
(desde el rompeolas me acuerdo de ti)
Vuelo controlado, colgado del palo
de las banderolas
Y ahora ya no puedo prestarte mi abrigo
ni quitarte la ropa, ni sudar contigo
ni perder la calma, ni decirte las cosas
que nunca te he dicho
Ahora ya no puedo prestarte mis alas
ni subirte la falda, ni cogerte con vicio
Ahora da lo mismo reírse de todo
que llorar por nada
cuando enrede los cabellos en tu nuca
Llévame al puerto de náufragos
y a los muelles que no escuchan tus preguntas
Desatando pañuelos de bruma
hace algunas horas que perdí la suma
(desde el rompeolas me alejo de ti)
Vuelo equivocado, tu voz es el viento
que rompe las olas.
de las banderolas
que llorar por nada
que rompe las olas.
Para mi y para tod@s los que se sientan identificados con la letra
Sola otra vez
Sola otra vez, ya ves... la cabeza en el suelo,
y me queda el consuelo del mundo al revés. Sola y después caer, sin mi alma, sin sueños, sin aire, sin nada que me haga volver a querer.
No sé porqué me levanto a diario, y me encuentro haciendo el amor con la pared. No sé porqué sola otra vez, y mis besos, mis sesos y excesos deshechos quedaron en tu piel.
¿Qué hicimos mal? Quizá callar, quizá perder la fé.
Y en cada sitio que estoy te veo a mi alrededor, y no te quiero, no te quiero perder.
¿Cómo volar si tienes mis alas? Ves, ¿cómo volar sin miedo a llorar después?. ¿Cómo andar si mis pies? Si mis pies me robaste y sé que no hay razón que no te haga volver.
Vendrás, lo sé. Necesito de nuevo enredarte en mi pelo, y atarte a mi piel. Loca de atar si tú no estás, y me queda ordenar los rincones que muerden
mi cruel soledad.
¿Qué vaciar si nada hay, si ya no quieres ver?
Que tú sin mi te caerás, que tú sin mi llorarás.
¿Por qué no quieres, no me quieres creer?
No, sin tí ya no hay lunas llenas. Y no, sin tí ya no hay agua nueva. Y no, no, no, no, yo sin tí tengo más sed, y no sé dónde beber, ámame.
Sola otra vez
mi cruel soledad.
Ohhh, me apropio un trocito, vale? Es preciosa esa canción, madre mía...Eärendil wrote:Para mi y xa kien la kera tb.. la dedike hace tiempo xo es ke es preciusss!!
Por cierto, Charlie.B, no sé qué te habrá ocurrido y quizás esta canción te deprima aún más... Pero te dedico una de esas que a mí me ayudan a llorar:
Ya no me acuerdo (Estopa)
Esta mañana
Ya no me acordaba
Cómo tocaban mis dedos
Esa guitarra que era
Para mí tu cuerpo
Ya no me acordaba lo que sentía
Cuando acariciaba tu pelo
Ya no me acuerdo
Si tus ojos eran marrones o negros
Como la noche o como el día
Que dejamos de vernos
Sólo recuerdo que llovía y que quedamos
En la parada del metro
Pero haciendo un gran esfuerzo,
Aún veo tu mirada
En cada espejo de cada ascensor
Donde cada noche
Me sube hasta el cielo
De moteles invernadero
Donde se jura algo tan efímero…
Ya no me acuerdo
Ni de tu risa
Ni de tu prisa
Por darme un beso
Ni qué botón
De tu camisa
Desabrochaba primero.
Ni qué rumba me bailabas
Cuando querías robarme el sueño
Dicen que el tiempo y el olvido
Son como hermanos gemelos
Que vas echando de más
Lo que un día echaste de menos
Yo qué culpa tengo
Si ya no me acuerdo
Aún veo tu mirada
Donde cada noche
Y tan eterno,
Ya no me acuerdo,
Ya no me acuerdo
